Help my New BlueSTAR II won't talk to CPU !!!
Postby mrcostar » July 11th, 2012, 9:30 pm
The latest BlueSTAR II model has a new USB chip which does not load the virtual com port (VCP) drivers by default. The IC mfg is aware of this issue, has issued an errata for it, and has fixed it in the new silicon. In the meantime, (until we release a new CPU that will have the drivers with it) you must follow these steps to enable it manually:
1. Open Device Manager
2. Open Universal Serial Bus Controllers
3. Double click on USB Serial Converter
4. Click on Advanced Tab
5. Click on Load VCP
6. Unplug BlueSTAR
7. Plug back in to load driver
This should then load the VCP driver and allow the CoSTAR Programming Utility to communicate with the BlueSTAR.
Re: Help my New BlueSTAR II won't talk to CPU !!!
Postby coyote » July 17th, 2012, 4:59 pm
Hi mrcostar,
Is the "BlueSTAR II" a new device or is that another name for the BlueSTAR 2010?
john
coyote
Postby mrcostar » July 18th, 2012, 9:48 pm
coyote wrote:Hi mrcostar,
john
Hi John,
The BlueSTAR II is the same device, but it is already modified for improved A2DP performance.
It also has the DSP code already installed.
Users with this device need only upgrade the CFW and .txt files to get streaming working.
Postby Omlifecrew » October 4th, 2013, 7:14 pm
STEP 4. Click on Advanced Tab does not exist on my Windows 7 Computer.
I have 3 options at the top, not 4. Description states...This device cannot start. (Code 10)
Postby Omlifecrew » October 6th, 2013, 6:11 pm
I also borrowed a Windows XP laptop and tried assuming it was a compatability issue however no luck. I cannot install the FTDI drivers suggested in the directions.
Postby mpentillier » November 8th, 2013, 4:51 pm
Greetings, I purchased the Bluestar unit in early summer and at that time I was running windows 7 on my laptop I was able to install the programming utility and everything worked fine. Since then I've upgraded to windows 8. Last night I connected my laptop to the COSTAR interface and everything froze up on me. I disconnected the usb cable restarted the laptop now I'm getting this message saying that COSTAR device not found also it's saying not able to read version. After doing a little bit of research I understand that I should possible update the VCP drivers for Windows 8.1. I downloaded the drivers unzipped the package now I'm stuck. I'm not sure what file to install or where to install it. Can anyone help me out? Also is there a way that I can reset the interface back to the factory setting?
I guess my laptop would have to communicate with the COSTAR unit in order to do this. Any help you can provide would be greatly appreciated.
I wish there was a Tech support number I could use.
I miss using my BlueStar unit :?
mpentillier
Postby JWPenner » September 6th, 2014, 6:52 pm
I have the same problem, did you ever find a solution?
JWPenner
Postby dheiman » September 8th, 2015, 11:37 pm
used generic plug in
used garmin cable
worked just fine
David
9-8-2015
dheiman
Postby dheiman » September 8th, 2015, 11:40 pm
sorry, generic did not work
lit all lights like it should but did not work, charging cable only
dheiman
